I recently got this thin blue frame around the edge of my screen. It is there no matter what app is running. Somebody please tell me how to get rid of this. Thank you.
Dan.
Go to Menu>Settings>More>Developer Options and see if anything is checked under the Drawing section and then uncheck it. Same for the Monitoring section.
Is Settings>Accessibility>"Magnification gestures" turned on?
It sounds like you've accidentally magnified the screen, that's what the blue frame usually signifies. Turn the setting off if you don't need it, it can be quite annoying
