Root Blue Nexus Clock?
novemberwhiskey
Where can I get this?
That's the DeskClock.apk from ApeX. You can just pull it and install it on your /system/app using root explorer, adb, etc. The regular methods ;)
Thanks, but I couldn't get it to install. I downloaded it just fine to my sdcard, but when I go to install it, it says "application not installed"
Although the apk is called deskclock, the installer only shows "clock" and has the same icon as the one already in my drawer. Do I have to uninstall sometime to get this to work?
EDIT
I also tried just dropping it in system/apps via root explorer but it is not showing up anywhere?
