Help Blue screens and shutdown after flashing a ROM
Hello everybody
I have a Sony Xperia T, and when I got tired of the stock ROM (JB 4.1.2), updated with PC Companion to 4.3, and everything started to go wrong. While daily use, the screen sometimes turned blue and afterwards the phone rebooted. This happened approximately once a week.
Less frequently, the phone shut down and I couldn't turn it on tipically by holding power button for few seconds. Otherwise, I had to press volume up + power keys until first vibration (I read this simulates battery removal) in order to start my phone.
I thought it might be due to the new ROM, so I flashed CM 10.2, but I had the same problem. Recently, I tried with PACMAN ROM and OmniROM (my current firmware), but it could not solve the problem neither.
Few weeks ago I read that this bug might be a kernel issue, but I'm not quite sure. Do you have any idea about what happens? Flashing a new kernel would end the problem? In that case, which one do you recommend? My phone is rooted, bootloader unlocked and TWRP.
Android version: 4.4.2
Kernel: 3.4.0-perf-g6f893a7
BUILD: pa_mint-userdebug 4.4.2. KVT49L 39 test keys
SELinux status: permissive
Thanks you all for your time.
