iram Android Enthusiast Jul 5, 2014 #1 Trying to connect lg volt to pc via blue tooth. Windows 7 says Bluetooth Peripheral Device doesn't have a driver Has any one been able to connect volt to pc successfully ............................. We seem to be missing blue tooth drivers for volt for windows
iram Android Enthusiast Jul 7, 2014 #2 Apparently they have bluetooth tether as well as wifi and usb tether blocked off. !!!!!!! Should have stayed with zte warp
Saxön Well-Known Member Jul 7, 2014 #3 iram said: Trying to connect lg volt to pc via blue tooth. Windows 7 says Bluetooth Peripheral Device doesn't have a driver Has any one been able to connect volt to pc successfully ............................. We seem to be missing blue tooth drivers for volt for windows Click to expand... Yes, and was able to transfer files no problem. Use google , and download latest lg united drivers. -=Thanks are always appreciated and Happy Modding=-
Saxön Well-Known Member Jul 7, 2014 #4 iram said: Apparently they have bluetooth tether as well as wifi and usb tether blocked off. !!!!!!! Should have stayed with zte warp Click to expand... You can with root and tether app. It's been posted how to elsewhere here. I accidentally hit thanks instead of reply on your post...doh, and this phone smokes the warp! Hope this was helpful -=Thanks are always appreciated and Happy Modding=-
bg4m3r Android Expert Jul 7, 2014 #5 Why bother with Bluetooth for file transfers? Just use AirDroid.
M MCF3778 Member Jul 29, 2014 #6 i tried to transfer files with BT.... it was so slow.... BT was never intended on file transfer since at best is only good for 1.5-3mbit speeds.....
