Help Blueish tint to display
rlb4
Just got 2 new Captivates. One of them has a noticeably blue screen compared to the other which is more white. It also keeps going back to the previous screen as if you hit the back button. It is random but happens alot. I did a hard reset but it still happens. I think I am going to exchange that one since it also has the blueish screen. I ordered the phones over the phone from AT&T. Can I just bring it into any corporate store and exchange it? Will they charge a restocking fee for an exchange? Do you think it is reasonable to ask to power on the phone to see if it has a blueish tint and try to find one that is more white?
Thanks. Is there a limit to the amount of times we can exchange the phone within the 30 days. On my receipt it says one time.
I exchanged one for gps problems and this one has less of a blueish tint...weird
Did the new one you got continue to have gps problems? I returned a Captivate because it had serious gps problems. I am very curious to know if your new unit worked. Thank you. My Captivate had a blue tint screen as well....
That's funny GPS is working too, I just compared side by side with an iPhone and they both found me inside my house within seconds.
The exchanged Captivate has working gps? Have you tried it while driving using Google Navigation yet? Awesome if it does....mine was really bad. Thx.
No, not yet, but I am going out in a few, so I will check back with results...I just read that other people had luck with a new phone too and then the GPS crapped out after a few days
I notice a very slight blue tint, which is most noticeable during the initial AT&T slash screen during startup. However, it is not an issue for me.
