benjamin7062
Member
Hello,
I'm able to pair with several A2DP devices (stereo bluetooth headset). I'm also able to play music through them for approximately five to ten seconds. At that time both devices lose sync.
The one I care about the most is a 2010 Toyota Nav. I can hit connect and it will connect for a second. I can then hit play through the car stereo and the phone receives the command. It then disconnects from Bluetooth and stops playing.
The status is usually:
"...Paired but not connected..."
I can repeat this process and keep connecting to it but I can not get more than 10 secs of audio to play through the vehicle (for media) before the phone tries to drop the connection again. Four other devices work with the same vehicle without issue? (Blackberries, iPhone, etc)
Any suggestions?
Thanks,
Benjamin
Any suggestions?
Thanks,
Benjamin
