I'm currently running KaosFroyo V36 on my Eris and am having a couple of issues. I'm wondering if anyone else who has had experience with this ROM had similar issues.
First off, and the most annoying, is an issue with bluetooth. Very frequently, my headset will disconnect from the phone mid-call. Sometimes it will reconnect within a few seconds. Sometimes I have to turn bluetooh off and then on again on the phone for it to reconnect. Sometimes I have to shut off the headset and turn it back on, and sometimes I have to reboot the phone for it to reconnect. This only seems to happen during calls. Sometimes it will do this several times over in a single call and I finally get tired of it and turn on speaker. I use BT Mono to route audio to my headset and it's never disconnected yet that way. At first, I thought my Jawbone was defective, but after trying another headset, I had the same results. There is a possibility that this is a hardware issue, but this started happening soon after I flashed to Froyo from stock, so I'm hoping that's the case.
My other issue is with Froyo's camera app. Every time the camera auto focuses or makes light adjustments, the picture will freeze for a second. These still frames also show up in any video recorded with the camera. Again, this only started happening after I flashed to Froyo.
) so when your headset disconnects,are you able to pick up the handset and talk to the person? or are they gone from there as well?
