Help Bluetooth Audio Troubles
pmanpman
Hi,
I had a Galaxy Note 1 for a few years, then towards to end of its lifespan, I started having troubles when I connected the bluetooth to my car. It'd play an audio file, but there would be gaps in the sound coming through, so if I was listening to a podcast for instance, it might say that "He came _____ at the weekend" and I'd have no idea what the underscore represented.
I figured that this was an issue with the phone, but when I moved to my note 3, the issues continued, so I attributed the problem to my car. However, my car works perfectly fine with an iPhone, and today I tested my phone in my mothers car and encountered to exact same issues.
I'm wondering if perhaps some software I have installed is causing the issue? It appears on multiple podcast players as well as the default music player.
Both cars have the Mercedes Benz COMAND system if that helps.
