I was wondering if there was a way to get better Bluetooth compatibility that you see with 2.3 roms on 2.2. I was hoping to get a mini keyboard but many people say it only works with 2.3 since the Bluetooth has been updated.
I am unable to connect a mini bluetooth keyboard to either lgp500h (2.2.1) or smsung 5501T (2.1) both unrooted. I have been reading that there is an issue with these and android.
I tried the keyboard with my bluetooth dongle and winxp laptop and noticed that when it wanted to connect the keyboard showed in the software a randomly 5 digit number that you entered on the bt keyboard and hit enter to pair.
I suspect this is the issue with a number of phones and this keyboard. If you don't know the random 5 digit number when pairing it won't work.
Experience. I am trying to pair and connect a windows xp (sp3) pro with
Evo 4g running cm7 2.3 using a bluetooth dongle. The password matching works
Then a brief connection and then a disconnect between the two.
Do you know if all bluetooth dongles are created equal, or is this a cm 7 our 2.3 bluetooth bug?
