madjpey
Member
This was a flawless process before 2.2 and now is ridiculous! Anyone else??
Use to get into my car, sync up with my car and start playing my music w/i a min or two. NOW it will sync -sometimes, can usually get it to start playing my music -but it stops periodically or if I get a call or make a call it will not resume the music -EVER! I have to go into the phone -turn off the bluetooth -wait a min, -turn the bluetooth back on, -re sync with my car, -go back to music player and restart music(doesn't automatically start).
This is ALL THE TIME with these scenario's.
Is this a known issue with 2.2? It certainly didn't happen with 2.1.
Just tried going from one bluetooth to another. First with my truck to my car and it wouldn't sync to the 2nd one. (Yes, I turned off the truck to make sure it wasn't connected) Then tried going from my earpiece to the truck (after turning bluetooth off and resetting as described above) and finally tried from earpiece to car and it wouldn't sync with the 2nd bluetooth any time. With 2.1 if I went from one bluetooth to the next, all I would have to do is make sure the previous bluetooth being used was turned off and then turn the next one on and it would sync right up with my phone. Now, not.
