Help Bluetooth consuming power even when switched off?
iriches
I've got an unbranded DHD on Orange in the UK. It's been updated to 2.3.5 / Sense 3.0.
Since then, Bluetooth always seems to show up at 1% battery usage - despite the fact that I never, ever use it, and it is always switched off.
Anyone else see this? 1% is not exactly a huge problem - but it is a bit odd...
Do you have widgetsoid or do you use widgetsoid for switch off Bluetooth? Then you are not completely switch off, go to "Setting>Wireless and network setting" and check "Bluetooth setting enable or disable.
Nope. Not using widgetsoid. My Bluetooth settings are all off, as shown in the
image below.
If you restart your device "Battery usage" statistics not reset to the zero. So wait for few days and again check it.
Thanks Andima - but it's still happening after a full battery-out reboot. Haven't tried factory restore yet - it's not that big a problem to be worth the hassle!
Was just wondering if anyone else had seen it or if it was just me?
