well, the app is free in the market, so you might want to just download it and see if it works for you!
I received the Voyager Pro Plus on Saturday. I haven't had time to test it out fully but I noticed a few things right away.
First, it DOES NOT say who is calling. It just rings. I am very disappointed about that but I knew that was a possibility.
Second, it does give directions while using TeleNav but there is an issue. For some reason it is not saying the first second or so of the notification. For example, if it is suppose to say "Go 2.5 miles then turn right onto Smith St.", the Go 2. is not stated and all I hear is "5 miles then turn right onto Smith St." This is a another very big disappointment. There is a huge difference between 1.5 miles and 5 miles.
I am getting tired of this with both droids I have owned. I just don't understand why the newest and greatest droid doesn't work properly with a bluetooth device when my old non smart phone Lotus worked perfectly. This is extremely frustrating. I like the sound quality and comfort of the Voyager Pro Plus but it doesn't work the way it is suppose to with the Evo3d or the Shift.
I am going to contact both Voyager and HTC about this to see if I can get anywhere. I imagine they will both just point fingers. In my opinion this isn't the way it should be. The newest and best smartphone should do what an over 2 year old non smart phone does with a similar device. Now I have spent money on two new headsets and I still can't get one to work the way the regular Voyager Pro did with my Lotus. Very very frustrating.
I have no problems with this on my Evo 3D. I think your choice of headset is the problem. Try the Jawbone. It announces the directions without cutting anything off.Not announcing the name of who is calling is not that big of a deal but it was nice while driving. I can live without that.
Not giving the first second of directions is an entirely different issue. It makes no sense to me why that is happening.
I am just very frustrated with both droids I've owned. They are great for using apps and playing games but in terms of it being a "phone" they suck compared to the Lotus. The Lotus was the best "phone" I've owned and I expect the newest and greatest to get better not worse.
I guess I could try another headset but my point is I shouldn't have to. I am very happy with the sound quality, comfort, and battery life of the Voyager Pro. I only purchased the Pro Plus to have the features that A2DP is suppose to provide. Why it doesn't work properly is beyond me.
Try the Jawbone. It works great. as far as comfort goes, it has a bunch of different earpieces for different sized ears (all included in the box). So mine is totally comfortable, small, great sound quality, and it works the way you would expect it to work (no cutting off the first line of nav announcements).I tried the Q2 and it works great. The only reason I didn't keep it is because it was uncomfortable for me and I found the sound quality to be inferior to the Voyager Pro. Those are personal opinions of course. You may find it very comfortable and the sound quality could be great for you.
Having issues with bt also,and think its the phone,and heres why, have the pro with the hero,no bubbles,no troubles,change to 3d and same bt and everybody says not as clear,paired with my wifes shift and everybody says it sounds great, switch to pro plus and 3d and its the same as the pro,as far as sound quality,WTF,am thinking this 3d is not as the great phone everybody or HTC is making it out to be,my wifes shift is the bomb,downloads faster and stronger signal,fewer dropped calls,HMMMM.Unless someone can help with clarity issues,figuring out a way to give this phone back and get a shift.I guess I could try another headset but my point is I shouldn't have to. I am very happy with the sound quality, comfort, and battery life of the Voyager Pro. I only purchased the Pro Plus to have the features that A2DP is suppose to provide. Why it doesn't work properly is beyond me.
