Your phone thinks it's in a dock (whatever the reasons are).
Search in your app drawer the stock app 'Dock Mode'.
After starting it, go to its settings (Menu button) and uncheck these autostart features (Dock and BT) ... voila
Harry
... This doesn't affect auto connecting to a BT headset does it?
Only if you use a dock. Do you? Harry
What are you BT settings? Are you paired with anything. Also what music app are you using?
).Is that loss of battery power when you are using the BT headphones? In that case it is not the music app but the constant BT transmission that is doing it. Mine looses very little power when I am using plug in headphones, but then I use Mixzing rather than the stock music app.
