Thank you! That's what I am leaning towards, however, I'm a bit confused. There's a 'kit' offered on Amazon, that has three components - what I'm confused about is why do I need two speakerphones? Why would they sell this as a 'bundle'?:I got the blueant supertooth 3, the speaker is really loud and clear, you can copy your contacts to it and it'll say the name when it calls, connects by itself when you enter the car(the sound of the door closing triggers pairing), can't find any faults with it yet.
Unfortunately I'm sending my BlueAnt S4 back after having trouble getting it to connect to my Captivate on a regular basis. It also says call from tech support no matter who is calling and often drops the call when I try and answer it. Still its better than the Motorola which hung the phone every time a call came in. Though the Motorola did everything else better including making a flawless connection every time the phone was in range. The search continues for a viable option to play podcasts, read IMs AND handle phone calls.
