It does connect, i have tried forgetting my headphones and re-connecting them. i have also tried resetting network and bluetooth options. nothing seems to workdoes your phone see the headphones? were you able to connect the headset initially? have you tried to forget the headphones and then re-connect it?
what phone do you have?
I have a Nokia G21, also i use JBL Tune 710BT headphones if that helps, my phone runs Android 13. Also i have had my headphones for over 3 months and they have worked fine, but one morning they just didn't work on my phone.Have you tried installing JBL's app?
Some earbuds/headphones won't work with just trying to use the Settings >> Bluetooth menu option. They require the manufacturer's app.![]()
JBL Headphones - Apps on Google Play
Redefine your music experience with JBL Headphones app.play.google.com
If the app is installed and your headphones don't work, what phone do you have and which version of Android is it currently running?
so have you used the app with your headphones, as suggetsed by @svim ?I have a Nokia G21, also i use JBL Tune 710BT headphones if that helps, my phone runs Android 13. Also i have had my headphones for over 3 months and they have worked fine, but one morning they just didn't work on my phone.
More details are typically better so yeah, phone model and headphone model make a difference -- i.e. your headphones, JBL Tune 720BT, is not listed in the About this app section in its Google Play Store page. The issue being since you didn't initially state any model involved it's all just supposition and guesswork as far as we're concerned. The missing fact that they were working OK previously on your Nokia but then just stopped is also a revelation that changes things. Please add other details you can think of that might be helpful.I have a Nokia G21, also i use JBL Tune 710BT headphones if that helps, my phone runs Android 13. Also i have had my headphones for over 3 months and they have worked fine, but one morning they just didn't work on my phone.
Currently, it would appear to be a matter where those headphones work OK with other phones but now not with just your Nokia. So that tentatively indicates the problem is centered on your Nokia and not the headphones themselves. Given all the things you've already tried -- forgetting, resetting, etc.-- that rules out the more obvious fixes.
-- Do you have other Bluetooth headphones or earbuds? Do they work OK on your Nokia G21?
-- In case you haven't tried this already, try using Clear data in the Bluetooth app itself. This wipes the app's cache and the app's settings/config data. There could be some kind of random corrupt file in Bluetooth app's config so you need to manually wipe it. Note the Bluetooth app isn't likely to show up in your Settings >> Apps menu, you'll probably need to start it up and then at the top contextual menu icon select Show system apps (or something worded similarly, it varies by manufacturer), so the Bluetooth app is temporarily visible in the app list.
-- If the problem is due to the Bluetooth firmware on your Nokia perhaps it was triggered by some kind of system update to the Android firmware. Did your Nokia do some kind of version upgrade about the same time the problem first started to occur?
-- The following suggestion is more of a last resort option. When you enable your phone's Developer Options menu, there will likely be several options regarding Bluetooth connectivity. More specifically, I'd suggest focusing on Bluetooth codecs.
Be very judicious about what changes you make using Developer Options. Don't randomly experiment, make specific changes one at a time, and document it so you can always just go back to the default setting.![]()
Android Developer Options Explained: Everything you can do with these settings
Android ships with a whole bunch of Developer Options that can unlock experimental and debugging features. Here's what these options do.www.xda-developers.com
I tried my old headphones bluetooth headphones and they did not work. Also if i remember right i restarted my phone before going to sleep but my phone didn't say anything about an update back then. I have also tried wiping bluetooth app cache but it's greyed out so i figured i wasn't supposed to do that. I have also tried messing with the bluetooth developer options and they did not seem to work. My headphones seem to be only supporting SBC Audio Codec and nothing else. Also when i was testing do they work with TikTok it gets laggy when i try to watch videos, i don't know if that helps but i figured i'd leave it in.it could be your headphones. have you tried other headsets and see if they work on your phone?
As I said I tried my old headphones bluetooth headphones and they did not work.but other headphones work on your phone?
So this contradicts your previous statements. Your headphones are working on your Nokia with some apps but not others?.... Also when i was testing do they work with TikTok it gets laggy when i try to watch videos, i don't know if that helps but i figured i'd leave it in.
No they do not work at all on my phone. Sorry if i was unclear.So this contradicts your previous statements. Your headphones are working on your Nokia with some apps but not others?
No but they do work on other phones. I believe the problem is with my phone and not the headphones. Also i tried other headphones and they did not work.Are your headphones fully charged?
I have resetted network settings multiple times but it didn't work. Also i don't really have time to go get it fixed so if you have any possible fixes please tell.OK, so it does appear to be an issue with your Nokia G21. More specifically Bluetooth functionality. Have you already tried the Reset Network Settings option in your phone?
If that didn't fix the problem, when did you purchase your G21? Since it's a relatively newly release model is there any chance it's still covered by a warranty? You might want to have it looked at by a trusted service shop in case this is a hardware-related issue.
Nokia G21 - Full phone specifications
www.gsmarena.com
