Help Bluetooth Headset with Google Navigation?
Jethro
Nov 10, 2009
104
3
Hi, I'm looking for anyone with experience using a Bluetooth Headset to receive Google Navigation prompts properly on a Droid Incredible (running 2.3.4).
I just purchased a Motorola HX550, which is pretty new and highly rated. But the Navigation voice prompts get cutoff at the beginning sometimes. I've read some people say this is a 'battery-saving' issue with the phone turning A2DP off. But I've read others saying it works fine.
- Anyone get Google Navigation working well (not cutting off) with a Bluetooth headset? If so, what model headset are you using??
Thanks. I've only got a few more days left to return this headset, but don't want to hassle if it's an Android/phone issue.
Hi after the Gingerbread update is when I started having problems on Droid I believe. Switch to Droid 2 same problem. went to Droid 4 same. All with Jawbone Icon. Bought a new Bose series 2 with the Droid 4. Still have the problem. It seem that when the taliking communication stops for a time there is a lag time when starting. I read someones thought of putting a one second delay befor the navagation talking after bluetooth is notified. Does that make since? Software issue for sure....:mad:
Upvote 0
BEST TECH IN 2023
Smartphones
