I was wondering if there is a bluetooth headset out there that would allow apps such as "TIKL" to work properly. I would also like to be able to listen to my music. Any Suggestions?
I don't know about TIKL but I am using a hand-me-down Jawbone from my wife that works perfectly for playing music while driving and being available for calls. It also gives me directions using GPS. Everything is automatic so if a call comes in the music stops then starts again when the call ends. Of course its all in one ear so no stereo.
I understand the quality of the newer ones is even better though mine works great.
I've used behind the head stereo headsets for a number of years. I am not familiar with your TIKL app but as for listening to tunes.. I do it all day daily and it works flawlessly with the Rez. The music is interrupted for incoming calls and the music restarts at the end of the call.... outstanding! I never miss a call and I have a much better attitude with my tunes being streamed via BT. I've used the same headsets for NAV purposes and that works great as well. My BT headsets are el cheapo sets.
I think my cost was $35 or so. The quality might not be there but I figured when they started working poorly.. I'd toss them and get another set. I'm on my third year with the fool things. Love em!
