Airplane mode disables bluetooth and I can't use my bluetooth stereo headphones on the plane. I have looked and I can't find a widget that will disable the cellular radio without disabling the bluetooth. Since many planes have WiFi Internet now, it should be okay to use bluetooth which uses the same 2.4GHz frequency. Does anyone know of a widget that will disable the cellular service without disabling the bluetooth radio?
