Help bluetooth issue (with speaker sounds)
gmcgirt
Weird issue here. Whenever I disconnect my Jawbone Era, the phone stops using the speaker for ringtones, media sounds, etc and uses the earpiece. If I reconnect the bluetooth headset, everything works fine through the headset, but on disconnect, everything goes through the ear-piece. I've tried stopping bluetooth prior to disconnection, disconnecting jawbone, turning jawbone off. . .etc. The sounds only come back if i pull the battery. Anyone else had this or know of a fix?
This happened the first time we connected the Plantronics 903 after the 2.2 update. After a reboot, I deleted the pairing, paired it again and the problem hasn't reoccurred.
