Help Bluetooth Issue
Ltgk20
My GNex has one small issue which I haven't read about anywhere else. At my work I have no signal (no cel phone does there) so I put it in airplane mode. As I leave work I take it out of airplane mode and it connects to everything as it should, including my bluetooth headset. After a while (has been a couple of minutes or 30 or so) the bluetooth will become inactive. It still shows to be connected but it's not. If I cycle bluetooth off then back on it will show it turned off and it attempts to turn back on but it never does. The same thing happens if I cycle airplane mode. The only way I've found to fix it is to cycle power which works every time. This problem only occurs after having been on airplane mode for an extended period of time.
I've been hesitant to try a factory reset or anything like that because otherwise my phone has been perfect: the battery life is great (3G, 4G, wifi, talking or whatever), it never lags, it has good signal (although the meter rarely shows it), etc.
Anyone seen anything like this or have any suggestions of what I might try.
