Help Bluetooth issues.. - FRUSTRATED
Billito13
Ok I am on my second phone and second master reset in 38 days now.... My Epic 4G will not stayed paired with either of my cars bluetooths. I get the phone saying that it is paired but not connected, most of the times it says bluetooths but I can not hear the person and they can't hear me. I try pressing the bluetooth button and it will not let me deactivate it it, I am forced to take the call in bluetooth format unless I turn bluetooth off.
This is getting rediculous, I can not be the only person experiencing this issue. Is there a fix? is there a feature that is causing on the phone that could be causing this?
What cars are you driving? Is the Epic listed as being compatible?
The Epic works fine with my Sonata Bluetooth, and did before we got the update to Froyo.
a 5 series BMW and a 2011 Cadillac. Phone works for about 1 or 2 days then the problems start.... When it works, it is good.. But then it looses connectivity.
Like I said phone was replaced for a new one, I got it replaced on tuesday and today it stopped working...
I don't have the froyo update....
Delete any pairing information your car stereos have and start fresh. If that doesn't work, wipe your phone, upgrade to 2.2, wipe your phone again and try again.
I will try that this weekend, if it doesn't work then I will switch phones.... Or does this sound more like an Android issue
i remember not too long ago someone having the issue with a BMW. search this thread and you may be able to find it. It seems that i remember the resolution being that it wasn't compatible with the BMW. . .don't know what to say about the caddie. maybe start driving cheaper cars?
lol.
lol.
I remember that as well, but I seem to recall BMW updated the Bluetooth in the car and it worked in the end...
