Hi,
I bought a brand new LG Volt, but I'm having some issues with bluetooth.
- I've tried to connect it to 6 devices so far; 2 iPhones 6, another Android phone, my car, a portable speaker and my earpiece). My iPhone sees the Volt, can pair, but can't connect (says the LG isn't compatible). The LG sees iPhone as well, can pair, but the actual connection never gets established, as the bluetooth symbol never lights up and just remains grayed out
- This other android phone sees the Volt, but can't connect to it. (this android phone, ZTE, connects seamlessly with my iPhone).
- My car and my earpiece don't even see it.
- My portable bluetooth speaker is the only device the Volt can connect with. In the meantime I bought another Volt. Same issue.
Any idea what could be the issue here?
Thanks!
P.S. Someone suggested I try the following, but that didn't work:
You need to establish a Master, in your case your iPhone since you hotspot it.
So, disable all Bluetooths.
Enable iPhone bluetooth.
Enable LG Volt and let it connect.
Thanks!
. Too bad because I kind of like this phone. I actually need it solely for google maps, but I still think it's a nice phone. Well, thank you very much for your help, I really appreciate it.
