Bluetooth keyboard/touchpad is working
Jaxmoto
Just wanted to put this out there....
I have this mini bluetooth keyboard/touchpad:
http://www.amazon.com/Mini-Bluetooth-Wireless-Keyboard-RT-MWK02/dp/B005JALJUQ/ref=sr_1_1?ie=UTF8&qid=1339033531&sr=8-1
I haven't used it much because I never had a phone that would connect with it.
The Evo V 4G will not only connect, it is FULLY functional. On that mini keyboard all of the options are working and the mouse pointer works with the touchpad just like Windows, it even recognizes taps as clicks.
Pair this up with the HDMI connection and you now have a fully functional media center on your TV, no hacks or mods required.
The range is not amazing, you want to be within about 20' with that unit. It is rechargeble via a mini usb port on the keyboard. It also has a rotate function for the touchpad, so you can hold it flat or like a tv remote.
Only thing I have not figured out is the function keys (home, menu, back, search). Not too big of a deal unless you are going back and forth.
Not saying this is the best bluetooth keyboard, just confirming it works well.
Do you have a PS3? If so, can you check if a PS3 controller will pair and work? I am planning on using this phone to play emulators on the go. This app shows if it is compatible.
Sorry, can't... oddly enough I have a PS3 but don't have any controllers, only the bluetooth remote (TV style) for it.
