Bluetooth killer?
Jiroma
Hi all, I am now on my third HTC desire hd handset. The first one lost its bluetooth function, worked fine for around 2 months then it would pair but not connect or it would disconnect after a minute or so. Next phone went the same way after a week. The only thing I can think that may be messing with the software is a charger I bought from a local phone unlocker/accessories type shop because I noticed when I plugged it in to charge some of the apps would start or it would make a call. Plan now is to keep them well apart and see how it goes. I'd rather do without the charger, and you know how difficult that will be with the power hungry desire, rather than using the charger to see if it fails again.
Jiroma
