Do you have notification sounds turned on (do you get a notification when you get a text message)? My EVO uses the same sound for both incoming messages and bluetooth connect. Also, if you have your ringer turned off (or very low) go to Menu, Settings, Sounds, Volume and see if "Use incoming call volume for notifications" is checked.
