Bluetooth on/off
gd123
Member
My curvefish bitton for blue tooth has disappeared and I cant find it to put back on homescreen.
It's not on the list of widgets after a long press on homescreen, but when i go to market it shows as installed - i have tried reinstalling.
Any ideas?
have you installed it onto the sd card? widgets do not work if installed on the sd card so go into your "manage apps" menu and check if it says "move to phone" if it does click it to move it back to the internal memory.
That was it - sure i'd tried that too - takes a while to appear back on the list after moving - but it had been moved to sd - really short of space on phone
