Help Bluetooth Paired device Password
GameRoot
Hello
I have a samung note edge paired with my Mitsubishi pajero 2015 car, and i forgot the password for free hand system for the card and i want to recover it, is there a way to know from my phone what was the password used to pair the device with the car ?
thanks
Regards
Soufiane
No, as the passcode is only used to confirm the initial pairing and isn't saved; thereafter the device is authenticated by its MAC address.
If it's a factory-fitted system then the default passcode should be listed in the user manual. A common default is 0000, btw.
