Is no-one else concerned that Google requires location services be enabled for bluetooth pairing from 6.0 on? How much privacy do we need to give up to satisfy big business?
The excuse given is that your mac address is no longer being used as an identifier between devices so they now use GPS. I'm not sure how well my FiBit One understands/interprets GPS signals.
That's strange, because I've just successfully paired a Jawbone earpiece with my Xperia Z3 (running Android 6.0.1) with location disabled. Maybe it's manufacturer-specific?
p.s. Please keep responses on-topic.
At work so here is one reference, but there is an official data sheet out there.
https://developer.android.com/intl/...android-6.0-changes.html#behavior-hardware-id
#So the solution to someone might be able to determine your location is to give you no option but to give them your precise location? How does that aid my privacy?
I know this is old, but I'm hoping someone has figured out a way around it. The problem I have with this is that it not only requires the app to have the permission, but requires the user to turn on location services. This is like requiring you to leave your front door open in order to prove that you understand that people can see into your windows.
By "the app" I assume you mean something like FitBit, as already discussed in this thread. That do require location tracking in order to work correctly. I think it's quite simple really, if you don't agree with the company's TOS or EULA, then don't buy and use their products.
BTW I've noticed the Bose Connect app requires precise GPS permissions for some reason. But you don't actually need that app to connect and use Bose headphones, they work just as well without it. They only have to play your music, and Bose Corporation does NOT need to know where you are
Yeh, there are various ways around these things.
