Help Bluetooth query
mattdanielc
Hi guys
I bought a wireless speaker in the lounge - it works over Bluetooth. Hooked it up to my S2 - no worries at all.
It streamed music fine...
However now when I want to play music via the speaker I have to go in to the Bluetooth menu... I see my speaker in the Bluetooth devices and it says 'Paired' - however the music won't come out of the speaker in this state. Instead I have to hold down over the speaker and click 'connect'. Now it will work fine.
Is there a way I can make my paired devices 'connect' automatically so I don't have to go in my settings every time before I can stream the music?
This is there same thing that occurs when I connect my BT mouse. I think this more to do d with the mouse or your speaker, in that they save power by shutting the power down. If it was constantly connected you'd probably find that the battery on the SGS2 would be flay very quickly?
Well I only turn bluetooth on when I wants use the speaker, so I want it to be connected rather than paired when I turn it on....is there a way round it do you know?
