Bluetooth range
shizack
I have a Plantronics Voyager Pro+ for voice calls and a Samsung WEP870 in stereo mode for music.
I get maybe 10 feet before the signal starts dropping.
On my old Blackberry 8530 I could get at least 35 feet before it started to break up using these same headsets.
Anyone know a fix for this or should I just deal with it? Not a big deal; just annoying.
Are these the same bluetooth devices you used with the blackberry?
The warp probably doesn't have the bluetooth range that the blackberry had. I know blackberry uses a better chipset, so probably no fix for that
"better chipset"? Citation needed.
I have no problems with range on mine, using a plantronics headset.
I've had the same issues going from a blackberry curve to the zte warp. its got so frustrating i just ordered wired headphones -_-
