gtpdjw
Just thought I would put this out there. For anyone that want's to do WiFi tethering but don't want to spend the extra money a month you can use Bluetooth tethering and it works great I using a rooted Droid X and these to apps. You can find both apps on Google play, the first app that you need to install on your phone is called FoxFi. After installing that get your tablet and install PdaNet Tablet. Ok now turn your Bluetooth on your phone and your tablet, next on your phone make sure that it is set to discoverable, next on your tablet launch the Pda app and tap configure. Once it's done you should see your phone model at the top like the pic. Ok now just tap the connect button and your live on the internet. Hope this helps
