Help bluetooth voice dialing lg p500
ramuk8or
hi i have an lg optimus one , i read that froyo supports bt voice dialing , but i dont know how to activate it in my phone , do i need to install any app for this, ???
You have to turn bluetooth on first, then you have to pair your headset. Then, you have to turn your headset on. It should work after that.
it works that way , but i cannot use voice dialling , a normal nokia phone would have a bluetooth head set where u just have to long press a button and you hear a beep and you say out the name of the person you want to call and it calls , i am not able to do that on my optimus one , anyone know abt this
I run a phoneshop and have a customer asking em about this same thing... Does the LG Optimus One support bluetooth voice dialling and if so how do we set it up?
voice dial does not work off the shelf , but i tried voice dialer app, it starts on pressing the bluetooth head set , but it does not understand what i say , my accent is not american,
Hi
I have a Motorola bluethooth headset that I used to make call with the standard voice recognition system of the phone and everything work fine for me....
Blord
the standard voice recognition system need data connection to work, i dont want to use data conn just to make a call
