Help Bluetooth voice dialing?
OldSmoky
Member
Anyone know if the bluetooth voice dialing works on the Galaxy S? I'll be getting the Fascinate if that makes any difference.
It has HFP 1.5+ enabled, but it doesn't work with either my Sony Dr-BT15 headset, or my Moto S805's, or my Nokia mono-BT headset (it does support last-caller callback though).
I know one person using his successfully with voice dialling using a hands free car kit though, so not sure exactly what the issue is here.
Thanks. I guess it will need 2.2 to work properly. I was hoping it would have Nuance which enables BT voice dialing to work the Droid X.
