Bluetooth Voice Dialing
rexscott
Ok, I have searched tons of threads any I may be just missing something but I need to be able to voice dial over BT with an in car system like the Blueant S4 due to new state law. I currently have the Eris rooted running 2.1 with XTRsense3.1 rom. I am sure this can't do it with this but can someone help me out with what decent roms would if any. I believe I would have to go to 2.2 but just can't find an answer to what roms are working well.
Thanks for all of your help !!
parrot minikit (if your looking to buy a new device) uses voice dialing once you have copied contacts to it. Im happy with mine and noise cancellation is decent in an 18 wheeler too
For the 2.2 ROMs I personally like Nonsensikal and FroShedYo, and yes I believe you have to go to 2.2 to get BT voice dialing. My car has built in BT and dialing works fine on both 2.1 and 2.2 ROMs, but in this case it's the car's system that is doing the actual dialing, not the phone (contacts are copied from the phone into the car's systems). So DWH's suggestion would likely work too.
