Help Bluetooth wont turn on
m4ckg
Hey guys first time poster great forum here! i was trying to connect with my macbook pro thru es file explorer using bluetooth and it never worked right so i kept retrying and then for some reason my bluetooth stopped turning on for the sensation 4g. now everytime i try to turn it on the B just spins and it never works..any suggestions?
Im not sure what you mean by the spinning B but try hitting the power button on the Sensation & opt to "restart" the phone, then try again....in the settings for bluetooth thier are some "advanced settings" you may need to select. Im not 100% sure on your BT connection problem with your Macbook as I dont own a Mac....I just know if somthing acts funny, reboot....best of luck!
