Help blutooth not disabled
harithejo
The Bluetooth on my P500 is always enabled. even if I disable the same it gets enabled by it own in couple of minutes. Can any body help to solve this??
Welcome to the forums!
It looks some application with "BLUETOOTH_ADMIN" permissions is running in background and turns bluetooth on automatically. You can install aSpotCat from Market, which lists permissions and stop or uninstall the bad behaving application then.
https://market.android.com/details?id=com.a0soft.gphone.aSpotCat&feature=search_result
PS: sorry, but it looks like aSpotCat can display just permissions, which are dangerous (cost money, read private data, track position, etc), so it will not list apps by bluetooth permissions. It can display it, but you can see the same in Settings / Applications / Manage application - tap on app and check the permissions.
