Root bo9 fully working straight from zte ota
if u go back to fully stock and do the update root will work but when u install cwm after u enter recovery and hit reboot sysytem is going to ask u to disable recovery make sure hits yes if u hit no when u go back to recovery is goint to be stock recovery hit yes and cwm will stay
if u dont want to go true all that having to put your phone fully stock download it
That 4shared site is bullshit. Just keeps popping up more web pages with the same crap instead of allowing download
Do I go into my build prop to change how it says chameleon? Also its saying my phone number is different then what it actually is in my contacts.
Every feature works for me. Just that my phone number shows up different in contacts and the chameleon thing both superficial issues lol. Did full factory reset after restore as well.
Change the build prop....it will say chameleon change it to boost mobile or sh#t mobile ur choice :-)...don't know about phone number thing though......I'm probably going to have to wait til tomorrow to download... wheres link?
I am fixing to crack these ZTE keys wide open, I WILL teach them to leave a fully accessible update.zip in my /cache partition just for me to copy to my SD Card.. It may be very soon you guys without a PC will be able to root straight through stock recovery.
