body glove case messed the phone up
SSinisterSS
when i was putting it on, it made the trimming "bow" out from the end of the keyboard. now i have to take the phone back and get another one....:mad:
i snapped it back on, im gonna go to vz tomorrow and return it for something else
thoes little tabe that grab the phone are too hard, they need to flex more so we can bend them so they can clear the phone's lips while going on.
I've put it on and taken it off a couple of times. It's kind of hard to get off, but I didn't have trouble putting it on.
now i know not to buy one now...i still dont know how i want to protect my phone :(
hope i dont decide when it's too late...i treat this thing like a baby right now im so worried ill scratch it or something
I don't get it. How could it cause damage like that? I didn't have any problems putting this case on. Can you post a picture of the damage?
ill have to try and get it to do it again, hopefully the trimming snaps back on or else im gonna have to replace the phone.
how did you guys put it on? the clip by the USB bent the trimming out on me.
No problems putting it on nor taking it off - about 6 times (I really, really really wanted to use the GPS Navigation feature. Repeatedly.
I am returning the Case, though, as I cannot keep taking it off and putting it back on every single time. Now it is time to find a nice leather case with a magnet that won't set the phone off....or, perhaps I'll go old skool and find one with a clasp / snap?
Also returning the car charger from VZW - for the price I paid there I can get a pair of 3 in 1 Micro USB chargers that work in both the car as well as an electrical outlet...and for a couple of bucks I can get longer 6' gold plated cables....
VZW over charges for their stuff, I see....
i got it on finally without it harming the phone, and the keyboard is hard as hell to slide. i think some of the rubber is coming into contact with something. im gonna take it back and look for something else with a belt clip
i am not a fan of hard cases...
rubber or gel is the way to go
hard cases always scratch phones..
I like the Body Glove case I got with the phone. Tedious to get off, yes, easy to get on (the clasps are designed to go on, not come off...without force.) If you use the slide out kb, the part of the case that encompasses the screen encroaches on the top row of keys just enough where it is noticeable. All in all I like it, but I don't use the slideout kb nor do I take the case off to do navagation.
so it still allows it to be used with the nav and the media dock?
The body glove from Verizon was the first case I bought. I had to return my broken phone 20 minutes after I got it because of the case. The case was making it hard to slide the keyboard out (well not hard, but it definitely required a stronger push of the screen to get the keyboard than when it's naked). The case was grabbing and it grabbed a button on the keyboard and ripped it out.
I have a cheap velcro case now (had a magnet case, but it kept triggering the phone).
I had a similar issue. I was trying out the body glove and the Verizon rep put it on. When she couldn't get it of she called over another guy and he took it off while the screen was open. He put so much pressure on the screen trying to get it off, the screen was loose along the edge where the keyboard is. I took it back to Best Buy yesterday and got another one.
I still have the original clear film over the screen that came with the phone (the one that had writing on it). Writing has since worn off, but the film is still clinging to the screen just fine after I cut off the corner tab. Waiting on my phantom skinz order to arrive....
while i was fighting it i was VERY aware of the screen, i was using the corners of the phone as pressure points taking the damn thing off. im thinking by cutting 1 of the holding tabs off that may do the trick of having an easy on/off system with these cases.
