Accessories Body Glove Case
FireBirdX
Has anyone heard if the Fascinate is going to get the gel Body Glove case on release day like the Captivate did? That Captivate case was awesome. It made the glossy phone less slippery to handle, didn't slide on flat surfaces, and was awesome to hold. Come on, there's gotta be one for the Fascinate, right? :)
I don't know about any body glove, but when I get my Fascinate, I will order the Otterbox defender case if they make one for the Fascinate. :)
Was in a Verizon store just now, looking at the Fascinate. The rep said yes, there will a Body Glove case, available on release day.
there are some nice cases on ebay
Question is, is the camera hole big enough for the flash too? I looked at some Vibrant cases thinking this would be a quick fix, but I forgot about this flash.
Bought the Body Glove case with my Fascinate at the Verizon store when I got my phone. I work on a ambulance in a busy urban area so my phone will be abused (not intentionally). The clip does rotate, but is flimsy, and feels like it is going to break off, but it can be removed. The phone is so thin, I just keep it in my shirt pocket. With my old Voyager phone, it was dropped with a Body Glove case and the the phone just "bounced" without damage. Expecting (hoping) for the same results. Forgot to add, the camera opening in the back is large enough for the camera lens and led flash. You just have to make sure the belt clip is rotated out of the way.
hey orangemt246,
I got the body glove too. Does it take a little force to snap shut the first few times? When you put the case on. All my sides clicked perfectly except for the last one which took a little force.
picked up BodyGlove case tonight @ local VZW store. Fit is pretty nice. Curious; I'm also looking for a car mount for GPS use; store had a window mount which i don't want. Want a dash mat or perhaps cup holder temporary mount. Anyone now of other temp mount device options?
The one VZW sales also has a plastic sticky plate that allows you to dashboard mount.
