Root Bonsai 4.0.1 question
MB15SC
Does the homescreen in Bonsai not rotate in landscape? I'm new to all of this and want to make sure it's not something I've done.
Thanks!
Uhhh... it should. I'm running MidNight 5.2 which is based off of Bonsai 4.0.1 and mine rotates 270 degrees.
Try downloading Android terminal (or any terminal emulator) from the market.
Run the app
Type the following two letters:
su (press enter - then you'll be prompted to "allow" SuperUser access - so hit allow)
Then type:
/system/bin/sensorcalibutil_yamaha (press enter)
Then you'll follow the instructions on the screen. What I do is lay the Epic on a table with the touch screen facing up. Keep the phone level - so just push down lightly on the keyboard. At this point press enter.
See if that helps. You might want to reboot after you exit out of the terminal session.
