Bookmark widgets
kathayes
1. Is there a way to create a grid of bookmark widgets for Chrome like the one that comes with the Note 2 for the default internet browser?
2. How do you change the bookmarks that are in the default bookmark widget?
Thanks in advance.
Thanks in advance.
Good question. I'll be watching this thread. I'm racing to finish The Hobbit before it comes out on the silver screen. =)
Easy way is to use the 1x1 bookmark widgets and drop them onto each other to Form a folder. You then have a grid when you open the folder.
Or
If I long press the home screen I find a chrome bookmark widget in the pop up list which does not appear in the widget drawer. .or is it just when chrome is set to be default browser?
Or
Sorry, must have posted it twice, not sure how..
