Help Bookmarks gone
keeylyme
Newbie here, so be gentle. I tried to remove a single bookmark by dragging it down the screen only to remove all the bookmarks entirely. Now if I try to set up a new bookmark i have no idea where it has gone because that "bookmarK' screen is completely empty.....HELP:(
It sounds like you just deleted the book mark widget off the homescreen. No biggie.
Just hit the little plus sign on the bottom of the screen next to the phone icon, click 'widget' then scroll down (if needed) until you see 'bookmarks'. Click that, put it where you want it, and you're good to go.
FAST SIMPLE WAY TO RECOVER YOUR BOOKMARKS ON SPRINT 4G
Go to your home screen, tap menu, tap add to home, tap widgets, a list of widgets appears , tap Bookmarks.
Viola', your bookmarks are back. Not only did I get my bookmark page back, which had disappeared , I got all my bookmarks back as well !!
Woo, not to mention Hoo!!
:o. :P
