(boost) as a WiFi HotSpot?
anode505
I lost my root with last update (I musta hit install over later :confused: )
But I'll go the flashing route for root if I can get it to be a hot spot form my Galaxy Tab 10.1 (though probably will anyways to get TitBU back)
So what works to make it a HotSpot?
TIA
I haven't tested, but I really see no reason you couldn't do this without rooting. You should try and report your success/failure back to us on an unrooted phone..
