Easiest way to do it would be to use Titanium Backup
Sent from my N860 using Tapatalk 2 Beta-5
Titanium backup is worth spending money on, you'll end up using it more then you think.
Two things every smart phone user (especially rooted ones) should have, purchased copy of titanium backup and dropbox, they're life savers.
here's a link to sign up with dropbox.
https://www.dropbox.com/referrals/NTg0MzUxMTY3OQ
You can also advanced restore the data from a cwm backup if the roms were based on the same build (b08c vs b08)
Make sure you flash jbirds data fix if you want to restore the data from cwm, then do a backup, flash noob and advanced restore the data and everything should be there, titanium is always a good idea too, honestly though it only takes about 15 minutes to manually install the apps I use and be up and running, guess I travel pretty light though lolI have B08c and im planning on using ur ROM n00b? And im gona try TB lol
Not sure on the battery, mine is normal, red on the signal just indicates weak signal
