external/qemu/target-i386/helper.c: In function 'cpu_inject_x86_mce':
external/qemu/target-i386/helper.c:1469: warning: left shift count >= width of type
external/qemu/target-i386/helper.c:1476: warning: left shift count >= width of type
external/qemu/target-i386/helper.c:1484: warning: left shift count >= width of type
external/qemu/target-i386/helper.c:1486: warning: left shift count >= width of type
external/qemu/target-i386/helper.c:1495: warning: left shift count >= width of type
external/qemu/target-i386/helper.c:1496: warning: left shift count >= width of type
external/qemu/target-i386/helper.c:1502: warning: left shift count >= width of type
external/qemu/target-i386/helper.c:1504: warning: left shift count >= width of type
external/qemu/target-i386/helper.c:1505: warning: left shift count >= width of type
external/qemu/target-i386/helper.c:1510: warning: left shift count >= width of type
host C: emulator-target-i386 <= external/qemu/target-i386/machine.c
host C: emulator-target-i386 <= external/qemu/fpu/softfloat-native.c
host C: emulator-target-i386 <= external/qemu/target-i386/kvm.c
host C: emulator-target-i386 <= external/qemu/target-i386/kvm-gs-restore.c
external/qemu/target-i386/kvm-gs-restore.c: In function 'take_signal_handler':
external/qemu/target-i386/kvm-gs-restore.c:72: warning: unused variable 'ret'
host C: emulator-target-i386 <= external/qemu/kvm-all.c
host C: emulator-target-i386 <= external/qemu/kvm-android.c
host C: emulator-target-i386 <= external/qemu/memcheck/memcheck.c
external/qemu/kvm-all.c: In function 'kvm_dirty_pages_log_change':
external/qemu/kvm-all.c:232: warning: format '%08x' expects type 'unsigned int', but argument 5 has type 'long unsigned int'
host C: emulator-target-i386 <= external/qemu/memcheck/memcheck_proc_management.c
host C: emulator-target-i386 <= external/qemu/memcheck/memcheck_malloc_map.c
host C: emulator-target-i386 <= external/qemu/memcheck/memcheck_mmrange_map.c
host C: emulator-target-i386 <= external/qemu/memcheck/memcheck_util.c
host C: emulator-target-i386 <= external/qemu/cpus.c
host C: emulator-target-i386 <= external/qemu/arch_init.c
host C: emulator-target-i386 <= external/qemu/os-posix.c
host C: emulator-target-i386 <= external/qemu/oslib-posix.c
host C++: etc1tool <= development/tools/etc1tool/etc1tool.cpp
<command-line>:0:0: warning: "_FORTIFY_SOURCE" redefined [enabled by default]
<built-in>:0:0: note: this is the location of the previous definition
development/tools/etc1tool/etc1tool.cpp: In function ‘void multipleEncodeDecodeCheck(bool*)’:
development/tools/etc1tool/etc1tool.cpp:477:94: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
development/tools/etc1tool/etc1tool.cpp: In function ‘int main(int, char**)’:
development/tools/etc1tool/etc1tool.cpp:502:54: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
development/tools/etc1tool/etc1tool.cpp:505:54: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
development/tools/etc1tool/etc1tool.cpp:523:76: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
development/tools/etc1tool/etc1tool.cpp:527:73: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
development/tools/etc1tool/etc1tool.cpp:533:50: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
development/tools/etc1tool/etc1tool.cpp:538:46: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
development/tools/etc1tool/etc1tool.cpp:545:37: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
development/tools/etc1tool/etc1tool.cpp:556:62: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
development/tools/etc1tool/etc1tool.cpp:560:40: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
development/tools/etc1tool/etc1tool.cpp:569:80: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
host C++: libETC1 <= frameworks/base/opengl/libs/ETC1/etc1.cpp
host C++: exc_dump <= sdk/emulator/qtools/trace_reader.cpp
host C++: exc_dump <= sdk/emulator/qtools/exc_dump.cpp
host C: fastboot <= system/core/fastboot/protocol.c
host C++: exc_dump <= sdk/emulator/qtools/decoder.cpp
host C: fastboot <= system/core/fastboot/engine.c
host C: fastboot <= system/core/fastboot/bootimg.c
host C: fastboot <= system/core/fastboot/fastboot.c
host C: fastboot <= system/core/fastboot/usb_linux.c
host C: fastboot <= system/core/fastboot/util_linux.c
host C: fs_config <= build/tools/fs_config/fs_config.c
host C: fs_get_stats <= build/tools/fs_get_stats/fs_get_stats.c
host C: genext2fs <= external/genext2fs/genext2fs.c
host C: gpttool <= system/core/gpttool/gpttool.c
system/core/gpttool/gpttool.c: In function ‘main’:
system/core/gpttool/gpttool.c:296:3: warning: implicit declaration of function ‘ioctl’ [-Wimplicit-function-declaration]
system/core/gpttool/gpttool.c: In function ‘show’:
system/core/gpttool/gpttool.c:175:7: warning: array subscript is above array bounds [-Warray-bounds]
host C++: hist_trace <= sdk/emulator/qtools/hist_trace.cpp
host C++: hist_trace <= sdk/emulator/qtools/trace_reader.cpp
host C++: hist_trace <= sdk/emulator/qtools/decoder.cpp
host C: hprof-conv <= dalvik/tools/hprof-conv/HprofConv.c
host C: icudata <= build/tools/bin2asm/icudata.c
host C: imgdiff <= bootable/recovery/applypatch/imgdiff.c
build/tools/bin2asm/icudata.c: In function ‘main’:
build/tools/bin2asm/icudata.c:18:20: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
host C: imgdiff <= bootable/recovery/applypatch/utils.c
host C: imgdiff <= bootable/recovery/applypatch/bsdiff.c
bootable/recovery/applypatch/bsdiff.c: In function ‘bsdiff’:
bootable/recovery/applypatch/bsdiff.c:224:5: warning: ‘pos’ may be used uninitialized in this function [-Wuninitialized]
host C++: jdwpspy <= development/tools/jdwpspy/Main.cpp
host C++: jdwpspy <= development/tools/jdwpspy/Net.cpp
host C++: jdwpspy <= development/tools/jdwpspy/find_JdwpConstants.cpp
host C: line_endings <= development/tools/line_endings/line_endings.c
host C++: localize <= frameworks/base/tools/localize/file_utils.cpp
host C++: localize <= frameworks/base/tools/localize/localize.cpp
host C++: localize <= frameworks/base/tools/localize/merge_res_and_xliff.cpp
host C++: localize <= frameworks/base/tools/localize/res_check.cpp
host C++: localize <= frameworks/base/tools/localize/xmb.cpp
host C++: localize <= frameworks/base/tools/localize/Configuration.cpp
host C++: localize <= frameworks/base/tools/localize/Perforce.cpp
host C++: localize <= frameworks/base/tools/localize/SourcePos.cpp
host C++: localize <= frameworks/base/tools/localize/Values.cpp
host C++: localize <= frameworks/base/tools/localize/ValuesFile.cpp
host C++: localize <= frameworks/base/tools/localize/XLIFFFile.cpp
host C++: localize <= frameworks/base/tools/localize/XMLHandler.cpp
host C++: localize <= frameworks/base/tools/localize/test.cpp
host C++: localize <= frameworks/base/tools/localize/localize_test.cpp
host C++: localize <= frameworks/base/tools/localize/merge_res_and_xliff_test.cpp
host C++: localize <= frameworks/base/tools/localize/Perforce_test.cpp
host C++: localize <= frameworks/base/tools/localize/ValuesFile_test.cpp
host C++: localize <= frameworks/base/tools/localize/XLIFFFile_test.cpp
host C++: localize <= frameworks/base/tools/localize/XMLHandler_test.cpp
host C++: make_cfst <= external/srec/tools/make_cfst/make_cfst.cpp
host C: make_ext4fs <= system/extras/ext4_utils/make_ext4fs_main.c
host C: libext4_utils <= system/extras/ext4_utils/make_ext4fs.c
In file included from /usr/include/c++/4.6/ext/hash_map:61:0,
from external/srec/tools/thirdparty/OpenFst/fst/lib/compat.h:30,
from external/srec/tools/thirdparty/OpenFst/fst/lib/weight.h:73,
from external/srec/tools/thirdparty/OpenFst/fst/lib/float-weight.h:25,
from external/srec/tools/thirdparty/OpenFst/fst/lib/arc.h:22,
from external/srec/tools/thirdparty/OpenFst/fst/lib/fst.h:23,
from external/srec/tools/thirdparty/OpenFst/fst/lib/fstlib.h:45,
from external/srec/tools/make_cfst/make_cfst.cpp:24:
/usr/include/c++/4.6/backward/backward_warning.h:33:2: warning: #warning This file includes at least one deprecated or antiquated header which may be removed without further notice at a future date. Please use a non-deprecated interface with equivalent functionality instead. For a listing of replacement headers and interfaces, consult the file backward_warning.h. To disable this warning use -Wno-deprecated. [-Wcpp]
In file included from external/srec/tools/thirdparty/OpenFst/fst/lib/fst.h:26:0,
external/srec/tools/thirdparty/OpenFst/fst/lib/register.h:58:46: warning: type qualifiers ignored on function return type [-Wignored-qualifiers]
external/srec/tools/thirdparty/OpenFst/fst/lib/register.h:62:52: warning: type qualifiers ignored on function return type [-Wignored-qualifiers]
In file included from external/srec/tools/thirdparty/OpenFst/fst/lib/fst.h:27:0,
external/srec/tools/thirdparty/OpenFst/fst/lib/symbol-table.h: In function ‘bool fst::CompatSymbols(const fst::SymbolTable*, const fst::SymbolTable*)’:
external/srec/tools/thirdparty/OpenFst/fst/lib/symbol-table.h:379:41: warning: suggest parentheses around ‘&&’ within ‘||’ [-Wparentheses]
In file included from external/srec/tools/thirdparty/OpenFst/fst/lib/vector-fst.h:27:0,
from external/srec/tools/thirdparty/OpenFst/fst/lib/fstlib.h:50,
external/srec/tools/thirdparty/OpenFst/fst/lib/test-properties.h: In function ‘uint64 fst::KnownProperties(uint64)’:
external/srec/tools/thirdparty/OpenFst/fst/lib/test-properties.h:38:38: warning: suggest parentheses around arithmetic in operand of ‘|’ [-Wparentheses]
In file included from external/srec/tools/thirdparty/OpenFst/fst/lib/fstlib.h:61:0,
external/srec/tools/thirdparty/OpenFst/fst/lib/encode.h: At global scope:
external/srec/tools/thirdparty/OpenFst/fst/lib/encode.h:177:24: warning: type qualifiers ignored on function return type [-Wignored-qualifiers]
external/srec/tools/thirdparty/OpenFst/fst/lib/encode.h:274:24: warning: type qualifiers ignored on function return type [-Wignored-qualifiers]
external/srec/tools/thirdparty/OpenFst/fst/lib/encode.h:275:27: warning: type qualifiers ignored on function return type [-Wignored-qualifiers]
In file included from external/srec/tools/thirdparty/OpenFst/fst/lib/rmepsilon.h:34:0,
from external/srec/tools/thirdparty/OpenFst/fst/lib/epsnormalize.h:31,
from external/srec/tools/thirdparty/OpenFst/fst/lib/fstlib.h:62,
external/srec/tools/thirdparty/OpenFst/fst/lib/queue.h: In static member function ‘static void fst::AutoQueue<S>::SccQueueType(const fst::Fst<Arc>&, const std::vector<A>&, std::vector<fst::QueueType>*, ArcFilter, Less*, bool*, bool*)’:
external/srec/tools/thirdparty/OpenFst/fst/lib/queue.h:672:17: warning: suggest explicit braces to avoid ambiguous ‘else’ [-Wparentheses]
In file included from external/srec/tools/thirdparty/OpenFst/fst/lib/minimize.h:33:0,
from external/srec/tools/thirdparty/OpenFst/fst/lib/fstlib.h:69,
external/srec/tools/thirdparty/OpenFst/fst/lib/partition.h: At global scope:
external/srec/tools/thirdparty/OpenFst/fst/lib/partition.h:215:39: warning: type qualifiers ignored on function return type [-Wignored-qualifiers]
In file included from external/srec/tools/thirdparty/OpenFst/fst/lib/fstlib.h:69:0,
external/srec/tools/thirdparty/OpenFst/fst/lib/minimize.h:368:31: warning: type qualifiers ignored on function return type [-Wignored-qualifiers]
In file included from external/srec/tools/thirdparty/OpenFst/fst/lib/fstlib.h:54:0,
external/srec/tools/thirdparty/OpenFst/fst/lib/arcsort.h: In member function ‘uint64 fst::OLabelCompare<A>::Properties(uint64) const [with A = fst::StdArc, uint64 = long long unsigned int]’:
external/srec/tools/thirdparty/OpenFst/fst/lib/arcsort.h:64:3: instantiated from ‘void fst::ArcSort(fst::MutableFst<Arc>*, Compare) [with Arc = fst::StdArc, Compare = fst::OLabelCompare<fst::StdArc>]’
external/srec/tools/make_cfst/make_cfst.cpp:243:47: instantiated from here
external/srec/tools/thirdparty/OpenFst/fst/lib/arcsort.h:299:41: warning: suggest parentheses around arithmetic in operand of ‘|’ [-Wparentheses]
In file included from external/srec/tools/thirdparty/OpenFst/fst/lib/float-weight.h:25:0,
external/srec/tools/thirdparty/OpenFst/fst/lib/weight.h: In constructor ‘fst::NaturalLess<W>::NaturalLess() [with W = fst::TropicalWeight]’:
external/srec/tools/thirdparty/OpenFst/fst/lib/queue.h:532:9: instantiated from ‘fst::AutoQueue<S>::AutoQueue(const fst::Fst<Arc>&, const std::vector<typename Arc::Weight>*, ArcFilter) [with Arc = fst::StdArc, ArcFilter = fst::EpsilonArcFilter<fst::StdArc>, S = int, typename Arc::Weight = fst::TropicalWeight]’
external/srec/tools/thirdparty/OpenFst/fst/lib/rmepsilon.h:294:74: instantiated from ‘void fst::RmEpsilon(fst::MutableFst<Arc>*, bool) [with Arc = fst::StdArc]’
external/srec/tools/make_cfst/make_cfst.cpp:236:45: instantiated from here
external/srec/tools/thirdparty/OpenFst/fst/lib/weight.h:127:5: warning: suggest parentheses around comparison in operand of ‘&’ [-Wparentheses]
host C: libext4_utils <= system/extras/ext4_utils/ext4fixup.c
host C: libext4_utils <= system/extras/ext4_utils/ext4_utils.c
host C: libext4_utils <= system/extras/ext4_utils/allocate.c
host C: libext4_utils <= system/extras/ext4_utils/backed_block.c
host C: libext4_utils <= system/extras/ext4_utils/output_file.c
host C: libext4_utils <= system/extras/ext4_utils/contents.c
host C: libext4_utils <= system/extras/ext4_utils/extent.c
host C: libext4_utils <= system/extras/ext4_utils/indirect.c
host C: libext4_utils <= system/extras/ext4_utils/uuid.c
host C: libext4_utils <= system/extras/ext4_utils/sha1.c
host C: libext4_utils <= system/extras/ext4_utils/sparse_crc32.c
host C: libext4_utils <= system/extras/ext4_utils/wipe.c
target thumb C: libext4_utils <= system/extras/ext4_utils/make_ext4fs.c
target thumb C: libext4_utils <= system/extras/ext4_utils/ext4fixup.c
target thumb C: libext4_utils <= system/extras/ext4_utils/ext4_utils.c
target thumb C: libext4_utils <= system/extras/ext4_utils/allocate.c
target thumb C: libext4_utils <= system/extras/ext4_utils/backed_block.c
target thumb C: libext4_utils <= system/extras/ext4_utils/output_file.c
target thumb C: libext4_utils <= system/extras/ext4_utils/contents.c
target thumb C: libext4_utils <= system/extras/ext4_utils/extent.c
target thumb C: libext4_utils <= system/extras/ext4_utils/indirect.c
target thumb C: libext4_utils <= system/extras/ext4_utils/uuid.c
target thumb C: libext4_utils <= system/extras/ext4_utils/sha1.c
target thumb C: libext4_utils <= system/extras/ext4_utils/sparse_crc32.c
target thumb C: libext4_utils <= system/extras/ext4_utils/wipe.c
host C: make_ve_grammar <= external/srec/tools/make_ve_grammar/make_ve_grammar.c
host C++: makekeycodes <= frameworks/base/tools/makekeycodes/makekeycodes.cpp
host C: minigzip <= external/zlib/minigzip.c
host C: mkbootfs <= system/core/cpio/mkbootfs.c
external/zlib/minigzip.c: In function ‘file_compress’:
external/zlib/minigzip.c:283:5: warning: implicit declaration of function ‘gzopen64’ [-Wimplicit-function-declaration]
external/zlib/minigzip.c:283:9: warning: assignment makes pointer from integer without a cast [enabled by default]
external/zlib/minigzip.c: In function ‘file_uncompress’:
external/zlib/minigzip.c:322:8: warning: assignment makes pointer from integer without a cast [enabled by default]
external/zlib/minigzip.c: In function ‘main’:
external/zlib/minigzip.c:412:26: warning: assignment makes pointer from integer without a cast [enabled by default]
system/core/cpio/mkbootfs.c: In function ‘_eject’:
system/core/cpio/mkbootfs.c:82:20: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
host C: mkbootimg <= system/core/mkbootimg/mkbootimg.c
host C: libmincrypt <= system/core/libmincrypt/rsa.c
system/core/mkbootimg/mkbootimg.c: In function ‘write_padding’:
system/core/mkbootimg/mkbootimg.c:88:34: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
system/core/mkbootimg/mkbootimg.c: In function ‘main’:
system/core/mkbootimg/mkbootimg.c:183:5: warning: pointer targets in passing argument 1 of ‘strcpy’ differ in signedness [-Wpointer-sign]
/usr/include/string.h:128:14: note: expected ‘char * __restrict__’ but argument is of type ‘unsigned char *’
system/core/mkbootimg/mkbootimg.c:228:9: warning: assignment discards ‘const’ qualifier from pointer target type [enabled by default]
system/core/mkbootimg/mkbootimg.c:241:48: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
system/core/mkbootimg/mkbootimg.c:244:50: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
system/core/mkbootimg/mkbootimg.c:248:52: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
host C: libmincrypt <= system/core/libmincrypt/sha.c
host C: mksdcard <= sdk/emulator/mksdcard/mksdcard.c
system/core/libmincrypt/sha.c: In function ‘SHA_update’:
system/core/libmincrypt/sha.c:153:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
host C: mkyaffs2image <= external/yaffs2/yaffs2/utils/mkyaffs2image.c
host C: mkyaffs2image <= external/yaffs2/yaffs2/yaffs_packedtags2.c
In file included from external/yaffs2/yaffs2/yaffs_guts.h:23:0,
from external/yaffs2/yaffs2/utils/mkyaffs2image.c:38:
external/yaffs2/yaffs2/devextras.h:210:0: warning: "DT_UNKNOWN" redefined [enabled by default]
/usr/include/dirent.h:101:0: note: this is the location of the previous definition
external/yaffs2/yaffs2/devextras.h:211:0: warning: "DT_FIFO" redefined [enabled by default]
/usr/include/dirent.h:103:0: note: this is the location of the previous definition
external/yaffs2/yaffs2/devextras.h:212:0: warning: "DT_CHR" redefined [enabled by default]
/usr/include/dirent.h:105:0: note: this is the location of the previous definition
external/yaffs2/yaffs2/devextras.h:213:0: warning: "DT_DIR" redefined [enabled by default]
/usr/include/dirent.h:107:0: note: this is the location of the previous definition
external/yaffs2/yaffs2/devextras.h:214:0: warning: "DT_BLK" redefined [enabled by default]
/usr/include/dirent.h:109:0: note: this is the location of the previous definition
external/yaffs2/yaffs2/devextras.h:215:0: warning: "DT_REG" redefined [enabled by default]
/usr/include/dirent.h:111:0: note: this is the location of the previous definition
external/yaffs2/yaffs2/devextras.h:216:0: warning: "DT_LNK" redefined [enabled by default]
/usr/include/dirent.h:113:0: note: this is the location of the previous definition
external/yaffs2/yaffs2/devextras.h:217:0: warning: "DT_SOCK" redefined [enabled by default]
/usr/include/dirent.h:115:0: note: this is the location of the previous definition
external/yaffs2/yaffs2/devextras.h:218:0: warning: "DT_WHT" redefined [enabled by default]
/usr/include/dirent.h:117:0: note: this is the location of the previous definition
In file included from external/yaffs2/yaffs2/utils/mkyaffs2image.c:40:0:
external/yaffs2/yaffs2/yaffs_tagsvalidity.h:23:6: warning: redundant redeclaration of ‘yaffs_InitialiseTags’ [-Wredundant-decls]
external/yaffs2/yaffs2/yaffs_guts.h:888:6: note: previous declaration of ‘yaffs_InitialiseTags’ was here
external/yaffs2/yaffs2/utils/mkyaffs2image.c: In function ‘write_object_header’:
external/yaffs2/yaffs2/utils/mkyaffs2image.c:195:44: warning: array subscript is above array bounds [-Warray-bounds]
external/yaffs2/yaffs2/utils/mkyaffs2image.c:195:19: warning: array subscript is above array bounds [-Warray-bounds]
external/yaffs2/yaffs2/utils/mkyaffs2image.c:196:44: warning: array subscript is above array bounds [-Warray-bounds]
external/yaffs2/yaffs2/utils/mkyaffs2image.c:196:19: warning: array subscript is above array bounds [-Warray-bounds]
In file included from external/yaffs2/yaffs2/yaffs_packedtags2.c:18:0:
host C: mkyaffs2image <= external/yaffs2/yaffs2/yaffs_ecc.c
host C: mkyaffs2image <= external/yaffs2/yaffs2/yaffs_tagsvalidity.c
host C++: obbtool <= frameworks/base/tools/obbtool/Main.cpp
In file included from external/yaffs2/yaffs2/yaffs_tagsvalidity.c:17:0:
host C: parseStringTest <= external/srec/tools/parseStringTest/parseStringTest.c
<command-line>:0:0: error: "_FORTIFY_SOURCE" redefined [-Werror]
cc1plus: all warnings being treated as errors
make: *** [out/host/linux-x86/obj/EXECUTABLES/obbtool_intermediates/Main.o] Error 1
make: *** Waiting for unfinished jobs....
external/qemu/target-i386/op_helper.c: In function 'helper_enter_mmx':
external/qemu/target-i386/op_helper.c:5445: warning: dereferencing type-punned pointer will break strict-aliasing rules
external/qemu/target-i386/op_helper.c: In function 'helper_emms':
external/qemu/target-i386/op_helper.c:5452: warning: dereferencing type-punned pointer will break strict-aliasing rules
