Root [Boost Mobile] b08c update not available
I've tried to update to da new firmware using the upgrade tool software and even when i go online to the support website it's not available i even tried to upgrade firmware thru my phone. I also noticed dat there were posts regardin fc's and constant reboots... did zte just remove the update because of the bugs because i have been tryin to find a way to update for 5 hours???
is the same i test the update and work said same version instaled:mad:
If you guys are rooted you can always install a b08c stock nandroid using CWM and i dont have any problems with this update and if your rooted and update to b08c you WILL lose root so i suggest flashing one of woodstock77's b08c nandroid
I copied the temp .zip it downloads just incase I need to send the phone back. They might remove the update some day and it's a good way to get the phone back to stock.
Sent from my N860 using Tapatalk 2 Beta-5
So if I'm running b08 and flash Woodstock 's b08c nandroid I won't have any issues correct? Just clarifying. I was hoping for a less complicated method to update. :)
if i already have data working on my CWM and flash woodstock's nandroid bo8c will i have to fix the CWM data issue again, and if so how? also can i replace the data ext in woodstock's nandroid with mine from b08?
I beleive you do have to fix cwm data again,theres a zip fix in one of hroarks posts and not sure about the data i think uou can
