Root [Boost Mobile] Battery calibration
Ok so this is to inform everyone that after installing new roms you need to calibrate you're battery. Also when installing any new battery otherwise your phone won't be using the correct battery percentages and will die even when it's not dead. Either delete battery stats in cwm or get the fee applies from the market that does it for you. It's called battery calibration
With fallout rom beta I added a battery calibration script to make a more precise battery percent. Until I get my laptop back I can't make a stable build. No one has reported problems so if you want to install it you can.
Thanks for the insight. I'm loyal to shins rom, maybe 1 day
Well you don't have to flash my rom all you have to do is Google battery calibration inid.t script and download to sd card then run the script in script manager and it will do the calibration in any rom.i liked shins rom until 1.5.1 then whenever I needed my phone say I'm lost and need gps phone was frozen... Try being lost in downtown Baltimore at 11pm, I quick made a stable system, I hear the oc is nice and new builds are more reliable shins a good developer
Lol funny I live in West Baltimore. But yeah I had the same problems initially with 1.5.1c. But it no longer has wifi issues or blue tooth. And I'm still using oc kernel. Idk i have enjoyed seeing the progression. I'll check out the script though
I love Baltimore, but it's gonna take a bit to get used to once I move closer, people coming from the country don't really fit in at first haha. I'm surrounded by rednecks here :'(. Anyways I just flashed his rom to see how it is, I like how he creates all these new features before anyone else does. It froze on the login screen so I flashed my rom back. I like shins work though.
