what is the diffrence between soft/hard bricking...or what causes a brick?
Okay to answer your question soft bricking can consist of bootlooping and getting stuck at the splash screen(android) phone will not boot up at all but cwm will work so you can fix with a restore or reflash
Hard bricking is worse adb wont recognize cwm wont recoginize and your phone will not boot (basically means you have a $200 paperweight)
As a warning be careful with what you do! And always remember make a backup or have one before trying anything!
Thanks lol...i dnt play around :b. I just download roms and install them. I make a backup everytime i install a diffrent rom..im running unitilogy but wanna try that warp sandwhich lol. Hope nothing happends.
Thanks alot ^.*
You will be fine![]()
