Root [Boost Mobile] changeing signal bar theme
Yes, but you need root access, and recovery installed if you want to use UOT Kitchen..
Are you rooted?
Are you rooted?
Yes I'm rooted if you don't mind telling me how to do this it would be great
You can do it... we can help
Uknow
I don't mind at all. You need access to framework-res.apk and systemui.apk. do you have recovery installed ? Are you on a stock rom?
Okay if you're on shins rom you can unzip the rom on your PC. Navigate to system/app for the system UI and system/framework for the framework-res.apk. go to uot kitchen. Google that cos I'm in mobile and can't remember the URL off the top of my head...and when I get a moment ill post a link to some other information cos you need to rename some files.
UOT:
http://uot.dakra.lt
How to theme signal bars:
http://androidforums.com/warp-all-t...y-change-signal-bars-edit-easier-reading.html
Follow the directions there after making a theme, flash in CWM, make sure you clear cache and whatnot. Then you should have themed bars.
Any questions, PM me or post here. I'll do my best to help you out.
Rom toolbox is super easy and user friendly and sometimes an icon wont work so pick another just be carful on boot animations some withh freeze up on boot the you get to reflash
