Root [Boost Mobile] Computer won't reconize phone in CWM mode
toast314
My computer will not recognize my phone is CWM mode? I've uninstalled and reinstalled driver not sure what I can do now , I am also using pdanet I have windows 7 64 bit so I followed all them steps also what can I do Now
When you say won't recognize, do you mean: a) adb not functioning, or b) phone/sdcard not mounted?
Let's start here.
jmar
I did not have that option , it showed unmount card so i did that and then remounted
What might help me help you is to know what you are trying to accomplish. For example: you want to push a file to the SD via adb?
Also, is your SDK for the 64bit version of Windows?
Just trying to narrow this down.
jmar
Sorry I can't be of more service to you for tonight. I don't own this device and need to go to bed for work early tomorrow. If I didn't work I would look into this further.
jmar
try this, it's been the source of a lot of the issues with drivers I think:
open dialer and enter *983*87274# choose AT
Hello guys,
All I wanted to do was do the manual update since I was unable to do it on my Warp because it is rooted. I tried to put it in FTM mode and it did not get there but to the CWM recovery mode! I was so frustrated that I wiped the partition from some other step I found online and did not work. I took my SD card out to put the stock recovery file to the root of the card on my pc then to my card then put the card back into my phone. Now my phone is not mounting my card!
Here's what I get:
Error mounting /sdcard!
Then when I wanted to get to the recovery file I get:
E:Can' mount /sdcard!
I had to format the card and try again, still the same thing! It cannot be the card! It's got to be the phone itself because the card works well on my windows 7 64-bit laptop! Please help asap! I miss having my phone on :( .
Format the card with the phone, Boot into recovery, choose advanced, partition sdcard
Agreed. The file systems used by Windows and Linux (Android) are very different. Android is very aware and therefore can read Linux, Windows and DOS file systems. Windows however (which apparently thinks it's the only operating system on the planet - after all, who could possibly ever need to read another format?) will not read Linux / Android partitions. When in CWM, however, only Linux formats are recognized, IIRC.
